ФОТОТЕХ
Bonus Tools (позднее Express Tools) из AutoCAD R14
Arx1meD-A1D
размещено: 08 Ноября 2021
обновлено: 08 Ноября 2021
Bonus Tools - это набор приложений, которые не вошли в основной пакет AutoCAD R14 (1998).
В некотором смысле раритет.
Перечень команд (из файла меню):
Copies entities nested inside blocks and xrefs: NCOPY
Extended change properties program: EXCHPROP
Layers of selected object(s) will be frozen: LAYFRZ
Lists extended entity data (xdata) attached to entity: XDLIST
Creates text which follows selected arc: ARCTEXT
Layers of selected object(s) will be turned off: LAYOFF
Starts AutoCAD drawing resources packaging program: PACK
Explode with options for controlling exploded entities' properties: XPLODE
Pedit for multiple polylines: MPEDIT
Find and replace text strings globally or by selection: FIND
Unconditionally converts old-style polylines to light weight polylines: CONVERTPLINES
Bonus Layer toolbar
Changes the layer of selected object(s) to the current layer: LAYCUR
Explodes text into polyline entities: TXTEXP
Saves dimension styles to a file: DIMEX
Thaws all layers in drawing: LAYTHW
Changes the layer of selected object(s) to the layer of a selected destination object: LAYMCH
Globally changes attribute values: GATTE
Imports dimension styles saved to a file with dimex: DIMIM
Extend to entities nested in blocks or xrefs: BEXTEND
Layer of selected object will be locked: LAYLCK
Layer of selected object will be unlocked: LAYULK
Displays properties of entities nested in external references or blocks: XLIST
Fits text between specified points: TEXTFIT
Creates object hiding entity useful for display and plotting: WIPEOUT
Changes attributes of multiple text items, including height, justification, location, rotation, style, text, and width: CHT
Layers of selected object(s) will be isolated: LAYISO
Trim to entities nested in blocks or xrefs: BTRIM
Bonus Standard toolbar
Collects specific entity types and makes them the current selection: GETSEL
Trim using closed polyline for cookie cutter effect: EXTRIM
Quick leader command: QLEADER
Explodes block and converts attributes to text: BURST
Turns on all layers in drawing: LAYON
Masks entities from behind text: TEXTMASK
Layer Manager saves and restores layer settings: LMAN
Attaches extended entity data (xdata) to any entity: XDATA
Dialog interface for editing system variables: SYSVDLG
Stretches with multiple selection windows: MSTRETCH
Bonus Text toolbar
Xclip with arc circle and polyline capability: CLIPIT
Move copy rotate and scale entities: MOCORO
Draws revision cloud on current layer: REVCLOUD
Associate a leader to an annotation object: QLATTACH
Disassociate leaders in a selection set from their annotation: QLDETACHSET
Associate leaders in a selection set to likely annotation: QLATTACHSET
Displays on-line help for the bonus applications.
Displays information about the bonus applications: BNSABOUT
Dialog based editor for the acad.pgp file: ALIASEDIT
Loads and unloads the bonus pop-up menu utility: BONUSPOPUP
В архиве:
AC_BONUS.CNT
AC_BONUS.DLL
AC_BONUS.HLP
AC_BONUS.LSP
AC_BONUS.MNL
AC_BONUS.MNU
ALIAS.EXE
ALIAS.HLP
ARCHITEC.LAY
ARCTEXT.ARX
ASCPOINT.LSP
BLK_LST.LSP
BLOCKQ.LSP
BNSABOUT.DCL
BNSABOUT.SLD
BNSABOUT.TXT
BNSLAYER.LSP
BURST.LSP
CHTEXT.LSP
CIVIL.LAY
CLIPIT.LSP
COUNT.LSP
CROSSREF.LSP
DBTRANS.ARX
DBTRANS.CPM
DBTRANS.DCL
DBTRANS.HLP
DEFAULTS.SVF
DIMSIO.ARX
DIMSIO.HLP
DLGTEST.DCL
DLGTEST.LSP
DOSLIB14.ARX
DOSLIB14.DOC
ELECTRIC.LAY
EXCHPROP.DCL
EXCHPROP.LSP
EXTRIM.LSP
FIND.DCL
FIND.LSP
FIREPROT.LAY
GATTE.LSP
GETSEL.LSP
JULIAN.LSP
LANDSCPE.LAY
LEADEREX.ARX
LEADEREX.CNT
LEADEREX.HLP
LMAN.DCL
LMAN.LSP
MECHANIC.LAY
MENU_DLL.TXT
MOCORO.ARX
MPEDIT.LSP
MSTRETCH.LSP
PACKNGO.ARX
PACKNGO.HLP
PLCONVRT.ARX
PLUMBING.LAY
POPUP.ARX
PQCHECK.LSP
REVCLOUD.LSP
SSX.LSP
STRUCTUR.LAY
SYSVDLG.ARX
TEXTFIT.LSP
TEXTMASK.LSP
TREXBLK.LSP
TXTEXP.LSP
WIPEOUT.ARX
XDATA.LSP
XLIST.DCL
XLIST.LSP
XPLODE.LSP
0.62 МБ
Инженерные консультации
